Old     (nick_in_ssp)      Join Date: Aug 2006       10-27-2018, 7:28 PM Reply
I am looking to do a project that controls two push pull solenoid actuators on a timed set 3-5 times each. To start the timed sequence I want to have it set off by a munual button. The thing is I have no idea where to start as far as electronics/controls. Is there a way to control with blue tooth from a phone through an app? How much does creating a phone app cost? I would like to be able to adjust time sequences fairly easy and also at a reasonable cost. 12 volt battery source. What signal could I use and how would it be sent to a relay?
Old     (fly135)      Join Date: Jun 2004       10-28-2018, 6:56 AM Reply
Have you been to the Adafruit website?
https://www.adafruit.com
They have all the things you need for a project like this. Search for "Arduino Uno Bluetooth". That would be a good platform for your project. The Uno doesn't have Bt built in so you need it added. I work with the ESP32, which has integrated wifi and Bt. Also quite a bit more powerful then the Uno. But your project doesn't need lot of power and the Uno is widely used and community supported. The Arduino IDE is a very simple dev environment but perfect for your application.
You should be able to find an Android app that's generic app for testing.
https://play.google.com/store/apps/d...uit.le.connect
https://maker.pro/arduino/tutorial/b...tphone-arduino
You can search relays on Adafruit and choose one that's suitable for driving the solenoids. The processor uses digital IO to turn them on/off.
Also Youtube is a valuable source of info....
https://www.youtube.com/results?sear...ooth+projects+
Old     (Michael)      Join Date: Mar 2010       11-01-2018, 9:26 AM Reply
is this for a surf setup?
Old     (acurtis_ttu)      Join Date: May 2004       11-05-2018, 11:42 AM Reply
gonna throw you a curveball, but my home automation does everything your talking about with my window shades, except for mine open close 2 times daily. I sue control 4...and I think some light stuff thru lutron
Old     (nick_in_ssp)      Join Date: Aug 2006       11-06-2018, 8:33 AM Reply
Not for surfing otherwise I would have put it in the boat thread.
Old     (denverd1)      Join Date: May 2004 Location: Tyler       11-07-2018, 2:14 PM Reply
going to arduino workshop on Saturday.
Nick, curious about your project
Old     (fly135)      Join Date: Jun 2004       11-19-2018, 10:28 AM Reply
How was the Arduino workshop?
Old     (denverd1)      Join Date: May 2004 Location: Tyler       11-20-2018, 11:39 AM Reply
actually didn't attend it. learned that ras Pi is likely a better tool for what I'm doing
