Thanks for the response.
First, id suggest you consult with your add-a-battery retailer for a custom wiring schematic. You should not be circumventing the switch, with the exception of a couple loads like an auto bilge.
There is not anything I'm trying to circumvent,
Just trying to get my switch panel wired to the house battery.
So its all wired up and the helm (switch panel) does not work but worked prior to the conversion? Sounds like there is a rogue B+ and B- that needs to be found or your wiring schematic is incorrect.
Everything works fine still, just can't find main power for switch panel.
Or, you are positive its drawing off the main and you want it to draw off the house. If this was a single battery boat originally, the helm BUS could be terminated to the starter's main B+ post.
I'm pretty positive that it is a single battery boat.
Model, year and engine of the boat might help.[/QUOTE]
1999 merc mag 5.7
