Old     (Laker1234)      Join Date: Mar 2010       06-03-2017, 12:15 PM Reply
Anyone know how to replace the yellow marker light on a 2003 Dorsey Trailer? The light is located in front of the fender. It looks as though the lens pops out because the fixture is riveted in but I don't want to start prying because I've never had to change one of these..
Old     (boardman74)      Join Date: Jul 2012       06-03-2017, 12:43 PM Reply
Most of those marker lights are sealed units and the whole thing gets replaced. Post a picture.
Old     (Laker1234)      Join Date: Mar 2010       06-03-2017, 2:00 PM Reply
That is what I was afraid of and I bet there is no way I can find one that will match. I'll try and get a picture.
Old     (Laker1234)      Join Date: Mar 2010       06-03-2017, 2:18 PM Reply
Old     (meathead65)      Join Date: Sep 2006       06-03-2017, 2:20 PM Reply
The light pops of the fixture. The two tabs at the top and bottom of the housing, gently pry them outward and the light assembly will release.
Old     (Laker1234)      Join Date: Mar 2010       06-03-2017, 3:58 PM Reply
So the yellow part is a sealed unit and not just a lens?
Old     (meathead65)      Join Date: Sep 2006       06-03-2017, 4:17 PM Reply
Correct. The chromed plastic is riveted or screwed to the trailer. The yellow fixture is sealed, you cannot replace just the light bulb. Those fixtures come in two styles, one has the wiring terminals centered in the fixture, one has the terminals offset about 1/3 of the way off center. You should be able to get either fixture at your local NAPA store, just take the bad one with you to match the terminal location.
Old     (Laker1234)      Join Date: Mar 2010       06-03-2017, 6:07 PM Reply
Thanks!!!!
Old     (jmanolinsky)      Join Date: Dec 2005       06-05-2017, 9:24 AM Reply
I ordered the same lights from Amazon. The light should have a number on it that identifies it.
