Originally Posted by timelinex
So I just used my drysuit in 60 degree air/water and it was great. Now the last remaining key is staying warm on the boat without too much hassle (enormous blankets). The other issue is there might be an occasional sprinkle which makes things like normal thermals/socks/shirts useless.
What are you guys using for clothes on the boat?
This year we are going to use .5 mill Caribbean style US Diver full wet suits with a dry long sleeve rash shirt and board shorts or underwear. These are for Extended Caribbean shallow water dives on 80+ degree water that over time can chill you in a non swim hard dive cause shallow no nitrogen sat and you go longer
These will be perfect on boat for both wind and cold and thin enough to easily pull off even with rear entry and easy to pull off and back in from waist if the sun made the black suit too warm!! the under clothes are for chafing(if wearing and driving for a while moving arms) and decency when others in boat not more layers
