Old     (bzubke1)      Join Date: Feb 2010       09-23-2016, 4:16 AM Reply
I remember them coming out a few years back but haven't heard much about them since. Anyone having good luck with them?
Old     (denverd1)      Join Date: May 2004 Location: Tyler       09-23-2016, 8:49 AM Reply
never tried one, but the consensus was they were nothing special to justify the higher costs. $800 prop? no thanks. My 3 blade will pull my arms with moderate weight. Of course its 10.5 pitch but we run quite a bit
Old     (TC_Mastercraf_X5)      Join Date: Feb 2013       09-23-2016, 9:10 AM Reply
I sold my OJ cinco as it didnt fit well with my wakeboarding needs. Thats said i heard its good for surfing, but i needed to go faster than 18 mph and it would NOT plane out... ACME 2315!
Old     (rallyart)      Join Date: Nov 2006       09-23-2016, 12:03 PM Reply
At low pitches you want fewer blades to get enough surface area facing back. A 3 blade is better at 11" pitch and a 4 blade is at 15" pitch. Five blades might help at higher pitches but the prop design always makes a difference. On my sterndrive, I got better performance from a vented 4 blade at 21" than I did from a High5 at that pitch and a five blade should be effective in that range.
If you have a 1:1 drive you don't want one, for sure.
Old     (duffymahoney)      Join Date: Sep 2008       09-24-2016, 8:15 AM Reply
I still use mine to this day, I think it's been 3 years or so. Best prop in the world. I surf with lower rpms then before and the boat is very happy all around. My max speed went down, but I never go that fast. I can surf with 4k in ballast and a large crew and the boat holds speed fine at 3,000 rpms. My motor is a 340hp marine power in my Tige 24v.
