Old     (sk4910)      Join Date: Jul 2011       09-06-2015, 11:10 AM Reply
I have a 2005 Sanger v210 that I tried to run today. I turned the key, the boat fitted up, and then the motor and everything electrical died. I havee 12v to the keyed switch, the 50 amp main breaker Has 12v leaving it, but nothing including the accessories has power. I do not have 12v leaving the switch, even when turning the switch. All the fuses I checked are good and I have not been able to locate any loose grounds. Please help.
Thanks,
Stephen
Old     (dp513)      Join Date: Jul 2011       09-07-2015, 2:38 PM Reply
check the main power supply to the motor. on my old 210 i had it come a little disconnected and it killed power to everything
Old    Paxdad            09-09-2015, 3:20 AM Reply
Check your safety lanyard switch.
Old     (Shakarocks)      Join Date: Mar 2013       09-09-2015, 8:52 AM Reply
What kind of motor do you have? My Merc Black Scorpion actually has two breakers on in the front and one in the back.
