Originally Posted by mro
Yes I have PP, and I think that's the problem as I can't find anything wrong at this point. It seems like the servo failed to wind up. Either it's going or I'm having a low voltage problem to the dash where PP is wired to
you can go into perfect pass and test the voltage getting to it. Hit menu and the up arrow at the same time. That should get you the menus where you can get system info. It's the same place that I have to scroll through to get the water temp.
Get a volt meter and test the voltage at your battery. Then power on the PP and see what kind of voltage the PP gauge is reading. if it's a big difference between the two, you've probably got crappy wiring between the battery and the PP. On my 92 Supra, I ran a good clean power and ground just for the PP and it cleared up a lot of the problems I was having.
