Not sure why you need someone else to re-program your timers. I've got a 2008 X also and I followed the Jabsco procedure and set mine to the max allowed (20 minutes). I fill an #1100 using my starboard tank overflow no problem. This is what the guide says:
• Obtain correct tank size
• Pump fills at approx 10 GPM
• Disconnect all battery from main boat connection for at least 30 seconds. Disconnect plug between
pump and the Active Intelligence box until programming is complete. Reconnect power from battery
and immediately start toggling switch to enter program mode.
• Push toggle to the fill position and toggle between fill and drain 5 times stopping in the off position each
time (fill-off-drain-off-fill-off, Etc.) Do not rush. This should be done in a slow methodical 1 second at
each position pace. Unit will blink when you have entered program mode and the number of blinks will
indicate the current fill time in 30 second intervals.
• To increase fill time - toggle between off and the fill position, each toggle increases the fill time by 30
seconds.
• To decrease fill time - toggle between off and drain position, each toggle decreases by 30 seconds.
• Increments are 30 seconds (approx 3.5 gallons per toggle) with minimum fill time of 30 seconds and
maximum of 20 minutes.
• Reconnect power to pump and run pump in drain cycle until pump stops automatically. This must be
done to reset unit to zero after programming.
If I remember right the "active intelligence box" is in the port locker on the panel closest to the cockpit. There's a connector there you unplug.
