02-27-2015, 1:14 AM
Ive got a ridiculous amount of boards lying around, at the back of my house, under the beds, on top of cabinets etc, I figured I should put them to use and make a wakeboard feature wall.
Id like to mount 15 boards up on the wall vertically. Just wondering if anyone else had done something similar?
Im trying to figure out a cheap way to do it, but so far all I can think of is drilling a hole through the boards and screwing them straight into the wall. I dont mind doing that with the old ones but Ive got some classic boards I dont really want to drill a hole through.
Ive looked at some mounts and they ok but they all seem to be around 20 bux per mount, so for 15 boards thats a bit steep.
Any ideas?
02-27-2015, 6:55 AM
Depending on how handy you are you could make something similar to the below. My grandpa and I built several of these to hold my numerous snow/wake boards that were always getting in the way. Once you have a template/cut out its SUPER easy to make more!
http://www.storeyourboard.com/premiu...-display-rack/
02-27-2015, 7:35 AM
I've used these many time to mount boards to the wall. You need 3 per board. You put two on the bottom to hold the board up and one on the top to secure it in place. These really only work if you want to display the top of the board, it's cool cause you can get the board flush against the wall. They also work great for hanging them from the ceiling. Super cheap, maybe like $2 at for 3 of them Home Depot.
02-27-2015, 7:55 AM
That's what I did, slapped it together in like an hour just so the boards were off the ground
02-27-2015, 9:21 AM
I made a bracket like the picture to mount a board in my living room before where I wanted it to look like it was floating. If you were to do a bunch I'd probably just make a shelf like the above picture. In my garage I just put screws through the fin holes and straight in to the cabinet I mounted them on.
02-27-2015, 9:35 AM
Door stoppers are cheap and easy for snowboard storage on the wall, a wakeboard would probably work as well.
http://tinylittlelife.org/?p=257
I have mine mounted vertical instead of as picture due to side cut of the board, it may be more challenging with a wakeboard though doing it this way due to convex sides.
02-28-2015, 3:14 PM
Another cheap option is a dry wall screw through a wine cork.
02-28-2015, 5:27 PM
dude that is slick. nicely done.
03-01-2015, 12:26 AM
Nice some great ideas. I need to make sure its fairly secure as the second row of boards will be about 6 ft up. Dont want any of them dropping out accidentally
03-01-2015, 3:40 PM
Hey Andy, what are those screw brackets called? Im trying to order them from the Home Depot website
03-02-2015, 8:06 AM
What if you just used fishing line through some of the fin holes? That would be a pretty easy way to get a floating look
03-02-2015, 1:10 PM
I did a search for L screw and they came up.
03-02-2015, 2:14 PM
if you're just doing one or two, you can mount through the fins holes pretty easily. stand off distance is something you'll have to tweak to get the look you're going for. Mounting them top to the wall would make them all look even and more flush
03-02-2015, 4:59 PM
I didnt even think of that! Nice idea. That could be the easiest way to do it. Not quite as nice a finish tho as the fishing wire would still be visible.
03-03-2015, 10:42 AM
Well with all these great ideas you better post a pic of the results, I'm really interested to see what you come up with
03-04-2015, 12:21 AM
Done! Turned out well I think. I ended up just mounting them through the fin holes.
Then for the boards im actually using I bought some brackets and mounted them straight onto another wall.
03-04-2015, 1:02 PM
Nice Job Mark, that looks legit!
03-08-2015, 8:30 AM
Looks Awesome Mark...
Not sure I could get this past the bride....
03-09-2015, 10:46 AM
I used to have that Weddington board.
03-09-2015, 2:37 PM
That looks fantastic! Very clean and classy. Great job!
03-11-2015, 8:51 PM
John such a good board ey, I learned a lot on that board
03-13-2015, 8:58 PM
I wish I had enough old boards to even do something like this. I always end up selling off my old stuff.
I wish more than anything that I still had my first wakeboard, a 96 Neptune Impala.
03-16-2015, 4:29 AM
yeh dude wish I still had my Hyperlite BAFF and the Murray honeycomb board eith the VW on it..
