take a tower turn so you've got a tight line, cut back inside a bit so you're under the cable, speed is not your friend when learning, you pretty much just want to turn the board and dig in further and further, as if you were trying to stop the cable, continue increasing the cut, and then I recommend throwing a roll for your first air trick. The scoop will come with practice and timing. Just continue the edging away, and then when you think you can't edge anymore, throw the roll. Keep your arms down and slightly in. Try and make it one easy motion where you roll it on edge and then increase that edge into throwing it up and away.
