I use lexol. They have a cleaner and a condishner. Both products work good. I have found that the condishner . Or what ever comes in the brown bottle does both and you only need to use that stuff. The cleaner is a clear gell like liquid that IMO does no better job at "cleaning " then the condishner. So if you just use the condishner you can delete the cleaner. Try both you might have diffrent results.
The thing I like about this stuff is I haven't found a leather product that has not liked it or reacted to it. It's very mild and most likely will not hurt you
Leather as alwasy try it on a small out of the way section first to make sure it works well with your type of material.
http://lexol.com
