07-08-2014, 3:05 PM
Definitely a warranty issue! Take them back for sure.
07-08-2014, 3:08 PM
I've had my Belmont Option 2s for 15 years and they are still holding up strong. That is definitely not normal for 2 weeks riding.
07-09-2014, 6:14 AM
I would say that would be pretty standard for those boots. I'm sure they will warranty it, but if you bought it at a Dick's sporting goods or other chain store, I'd push for cash and then find a pro shop or shop online. That board was never really meant to be used. It isn't even really an entry level set up. It is a throw in the ski-locker and use once a year kind of board.
There are a lot of great options in clearance sections, classifieds and craigslist for $300 or so. I'm talking top-end set-ups.
Also, I'm not making a general statement about Obrien. They make some great stuff. This just isn't it.
07-09-2014, 6:50 AM
Guessing that by O'neil you mean O'Brien. This is a warranty issue, contact them here http://www.obrien.com/warranty/ fill out the form, attach pictures, and they should be able to shoot you out some new boots asap. If you have any issues let me know and I will see what I can get done, but this should be no problem. If your riding that much you have probably already passed (in ability) the need for a beginner set up, I would move on to something more advanced. The O'brien Connect boot would be a prefect next step and you could stay on the System board. My gut tells me your wrenching the boots on and then ratcheting them down for a tight fit. The system boots are really designed for the person who is learning on day one and maybe the first year of riding after that. Very forgiving, the come off easy if you crash. I have that set up in my boat as the starter set up for noobies, the boots themselves are a universal fit from size 7-12, you will be blown away by the performance difference between a universal boot and a true shoe fit boot.
Keep me posted.
07-09-2014, 6:53 AM
Oh and don't waste your time going to Dick's if you bought it there go right to O'Brien, if you bought from a pro shop however I would go back in there, they will most likely (or should) give you new boots on the spot.
07-09-2014, 7:06 AM
Can you just return it and get your money back?
07-09-2014, 11:47 AM
Keep me posted.
You're correct, I meant O'brien, not O'neil- oops! Thanks for the insight. I figured $200 would be a decent price to start at, but it sounds like I might have thought wrong. I have found myself needing to tighten them down quite a bit, and they do fall off a lot. How compatible are bindings amongst different boards? Say for instance I purchased a new set of Connect bindings..would they work if I switched boards?
I've submitted a warranty claim to O'brien, kind of considering returning the board to Academy.
07-09-2014, 11:56 AM
If the store was local, I wouldn't even consider warranty service until I tried to return it. O'Brien might send you a new set of boots just by sending a snapshot, but you'd still be in the same situation of them falling apart again.
07-09-2014, 11:57 AM
Most bindings work on most boards. There are a few exceptions, but that's the general rule. Unless you're rocking something really old school, you can pretty much choose whatever bindings you like best and put them on just about any board. They are pretty universal.
07-09-2014, 3:10 PM
I should probably start a new thread (and this has probably been asked a million times), but what is a good board for ~$300? I'm 180lbs, hence the system being a 140.
07-15-2014, 6:14 AM
Hey Andy, sent you a PM.
07-15-2014, 7:03 AM
07-15-2014, 12:32 PM
Hey Manoffew,
Ross Dantonio here with O'Brien, looks like you're definitely a stronger rider than the Device bindings were designed for. Please reach out to Sirianna in our customer service department we'll take care of ya! Sirianna can be reached at:
SiriannaT@obrien.com
(425) 831-1065 ext 165
If anyone else has any issues with O'Brien please reach out as well.
07-15-2014, 1:56 PM
Ha Ross Beat me to it! I just sent Sirianna an email on your behalf. Let me know if you have any more issues!
07-15-2014, 3:07 PM
Sent you a PM man, I talked with Siranna and she has all your contact information! She will help you out.
07-26-2014, 6:26 PM
I don't think it would be fair not to follow up with this thread....
O'brien sent a brand new pair of connect bindings to me, and I couldn't be happier. +1 for the folks at O'brien, thank you!
