Originally Posted by duffy
What is the deal with the new LF wakeboards? Are you able to use different brand boots with the newer LF boards? I have 2011 Watson w/cells but I’m hearing the newer LF’s you can’t interchange them due to a new system? Can anyone elaborate?
My son is using 2012 Ronix Ones with his 2012 Watson Hybrid board with the Ronix binding hardware. Maybe it is the new 6mm screws that LF is using on their 2012 boards that they mentioned. Just make sure the binding hardware you use is 6mm and it should be fine.
