Old     (tonyv420)      Join Date: Jul 2007       03-14-2012, 9:19 AM Reply
Going to change the oil for the first time in my new motor (454) in my 1998 CK3500. What is everyone running in their tow vehicles? I broke the crank in my last motor hauling my camper and boat up Vantage 10 mile hill. Really want to put in the best protection I can get. Thanks in advance!
Old     (ixfe)      Join Date: Aug 2008       03-14-2012, 9:25 AM Reply
Funny you should ask... I just changed oil last night!
I always run Amsoil (5W 30). I also use an Amsoil filter. This stuff is great and is advertised to last up to 25K miles. In my case I change oil & filter once a year (about 15k miles for us).
Total cost for 6 quarts + filter = $65.
Old     (roomservice)      Join Date: Dec 2006       03-14-2012, 9:45 AM Reply
agree, synthetic, but do be careful if you go with an extended mileage oil since 454's burn oil, just keep an eye on the oil level between changes.
Old     (lifetimewarranty)      Join Date: Oct 2008       03-14-2012, 10:52 AM Reply
Mobile 1
And I only change one time a year also
Old     (denverd1)      Join Date: May 2004 Location: Tyler       03-14-2012, 11:56 AM Reply
people who know use Amsoil
Old     (you_da_man)      Join Date: Sep 2009       03-14-2012, 12:46 PM Reply
12 quarts of Amsoil
Old     (rdlangston13)      Join Date: Feb 2011       03-14-2012, 2:56 PM Reply
i used 5w-20 Mobil 1 full syn in my hemi dodge and change it every 5k miles. Run Amsoil 15w-40 in the boat and change it every 100 hrs
Old     (durty_curt)      Join Date: Apr 2008       03-14-2012, 3:33 PM Reply
I run Valvoline 15w40 in my 08 duramax.
Old     (rallyart)      Join Date: Nov 2006       03-14-2012, 4:27 PM Reply
I use Mobil 1 as a first choice in everything. Any good quality brand pure synthetic is better with high oil temperatures than conventional oil. If you don't have high temperatures you can just use regular oil and change it more often. If your engine starts to leak oil then switch away from synthetic as it leaks faster.
Mobil 1 had less internal friction than Amsoil when I ran dyno tests on various products. I was sponsored for product by Amsoil at the time.
Old     (murphy_smith)      Join Date: Dec 2005       03-14-2012, 4:28 PM Reply
My weekend truck is 2001 Chevy Tahoe with 211k miles on it. I have run conventional penzoil in it from day one. Dropped the oil pan 3 months ago b/c the oil pump went out and needed to replaced and did a new timing chain as well.
No sludge at all...engine runs smooth as hell.
Penzoil conventional is a cheaper oil - and I have gotten 211k miles out of my truck with 5k mile interval oil changes. Never had to do any internal engine work either other than oil pump...wearable part
Old     (mhunter)      Join Date: Mar 2008       03-14-2012, 7:38 PM Reply
Maybe if you used synthetic it wouldn't have worn out the pump???? GMC recommends Mobil 1 .
Old     (durty_curt)      Join Date: Apr 2008       03-14-2012, 8:31 PM Reply
. . . And Cummins recommends/endorses Valvoline
Old     (nitrousbird)      Join Date: Sep 2008       03-15-2012, 3:13 AM Reply
I run Valvoline 5W30 in the winter, 10W30 in the summer, covential on my 02 Avalanche with the 5.3L. 141k miles now, doesn't burn or leak a drop - actually, only thing I've ever done to the motor was plugs and wires @ 100k and changed the oil/filter around every 5k (whenever the change oil message comes up on the display).
Old     (Bumpass1)      Join Date: Oct 2010       03-15-2012, 3:26 AM Reply
Mobil One 0-40 is what my truck came with and I continue to use the same thing today. 8.5 quarts per oil change.
Old     (cadunkle)      Join Date: Jul 2009 Location: NJ       03-15-2012, 3:04 PM Reply
Now the 454 is a far inferior design than the Ford 460, but I see no reason why they would be any more likely to burn oil than any other modern and similar design V8. How is the oil more prone to reach the chamber than any other engine? I'm no Chevy expert, but you're looking at an extremely similar design to other big blocks.
Old     (tonyv420)      Join Date: Jul 2007       03-16-2012, 11:54 AM Reply
I had a ford, and replaced the exhaust minifolds 5 times in 5 years (kept cracking) in my 351 (F-250). So I bought a chev. and blew up the 454, Guess I should have bought a F-350. Oh well, I'm stuck with what I got ... ( no more money lol)
