Would it be possible to instal the bennet smart/wakeplate on a 08 x-star LY6 +/- 3350lbs ballast? the boat has a 14.5x14.25 at the moment,i guess a smartplate in combination with a 14.5x15.75 might save some fuel & better performance,lower rpm. any info?
^^^ Just name it differently. You aren't coping anyone. Tige with their TAPS plate, Supra with the Smartplate, MB's have TAP plates also, ... They all do about the same thing.
a simpel version would work like below 18 down and above up.i,m not for a manually trim plate,just more work for the ms. Darren are there aftermarket systems like yours?
David, supra's smart plate is a electronic system integrated with it's trim tab that automatically adjust the trim tab based on speed. The settings are pre-set by the driver. No other manufacturer has this ....yet.
They've had it for a couple of years. Saves gas getting on plane faster with weight. Sounds a lot more useful to someone that actually wakeboards than Johnny Space Commander gauge pods MC is too busy building yachts to think of things like that.
