Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through September 04, 2009
Old     (bzager)      Join Date: Apr 2009       08-09-2009, 8:49 PM Reply
anyone have any reason this might be? btw, its 2003 Sea Ray I/O. It sorta came out of nowhere, we noticed the engine running a tad rough, and the tacometer has been sticking (about 2000RPM's higher than normal), but its been running well enough for us to use the boat normally and ride. Any reason the water tempature gauge is running abnormally low?
Old     (rallyart)      Join Date: Nov 2006       08-09-2009, 9:23 PM Reply
Might have the thermostat stuck open some. Water temp would be low and the engine would be rough and idle higher because it was cold. Try replacing that.
It could also be a ground fault in the dash wiring. look under the dash and check for loose or corroded wires.
Old     (watsoc)      Join Date: Apr 2005       08-10-2009, 7:41 AM Reply
I would think Art is right in that your thermostat is likely stuck open.
Old     (denverd1)      Join Date: May 2004 Location: Tyler       08-10-2009, 8:17 AM Reply
I haven't run a stat in a couple years... always 160*. I don't think that's it, but Art is an engine ninja and generally correct with his diagnosis... but I guess for the fun of it I'll throw mine in as well.
I would say the ground under the dash is loose since you have the tach doin its thing.... but the temp gauge is one wire and wouldn't be affected....... hmmmmm... I'm stumped.
Old     (bzager)      Join Date: Apr 2009       08-10-2009, 9:43 PM Reply
ill check the thermostat and the wiring behind the dash, thanks for the help.
