quote:By Isaac Gredinberg (extremeisaac) on Tuesday, July 28, 2009 - 8:52 am:
get some Marine Gu and seal around all the areas where you have any fittings going through the transom.. easy fix
Ya, easy fix if you want your transom to fall apart!
Post some pictures. You PROBABLY need to remove the bracket or fitting, reglass or epoxy the hole walls, and replace the fitting. Transoms often have through fittings in them that were done by some weekend warrior who failed to glass or epoxy the hole walls. Water seeps in to the actual transom area from this hole and deteriorates the transom....
