06-22-2009, 8:49 PM
I am new to wakesurfing. We only have been doing it a couple times. I'm a big guy, 6'4 275 and I'm using a Landlock. We have a really good wake going but no matter what I do I cant surf on my own. Every time I try and let slack in the line I just drift away from the boat. If I lean too far forward the board goes under. Any suggestions?
06-22-2009, 9:28 PM
Board is probably not big enough for your weight. I am your weight and I started on a 6'2" board. As I got better I was able to ride smaller boards 5'.
06-22-2009, 10:03 PM
Collin, while that board is long it isn't buoyant or fast. I'm 245 and my daughter is 55lbs and I can ride my The Walker Project comp 5.0 with both of us on it. I've also seen a pic of Tim Whites brother in law whom also weighed 275lbs riding the same board. Here is a link to it. TWP Composite X
06-23-2009, 6:24 AM
looking at pics from another thread could I be standing too far back? My back foot is all the way back on the black pad.
06-23-2009, 8:26 AM
Get a new board. Stay away from "HyperForce" any of the small company's will have a board for you...
06-24-2009, 9:52 AM
I think... For your riding level, your "hyperforce" - i.e. Big Corporate board is fine, it's designed for heavier, beginning riders. It may have more to do with where you are riding the wake. If you are too low, you will not have enough wave to maintain forward motion regardless of how big the wake is. Try putting a little more weight on your toes and riding a little higher on the wake. Finding the sweet spot is tough but once you feel it, then every time you ride it will get better. It won't happen all in one session. If you can put your weight far enough forward to plow the nose, you are not standing too far back.
06-24-2009, 2:24 PM
Collin, Move that rear foot forward and the board will have more speed, concentrate on pushing on the front foot to accelerate or go down the wave and the back to slow down or move up the wave. We've got 250+ pounders on the same board and some can surf ropeless some can't
06-24-2009, 7:15 PM
Collin - not sure what you are calling a really good wake, but size does matter here. I have an Enzo 230 with an Enzo sack and with my landlock I find going 13mph is too fast, at 10.5 it is much easier to hold the wave. I also tend to stand much further forward on it, I can actually easily surf standing in the middle to front of the board. I also have a small Walker bullet (I think 54") that is a lot easier to surf than the landlock. But you still have to steer the board and stay in the pocket or you are going to drop out. Keep at it and you'll get it, your size is not an issue, with the right board and technique "you can do it"!
06-24-2009, 7:21 PM
Collin - check this one out, keep it up and this could be you (he is on a walker bullet, albeit a bit larger than mine) http://www.youtube.com/watch?v=ic5yyNMJllc
06-24-2009, 8:03 PM
Hey Oldwakedude, Thanks for the props ( that is me in the video) Yes my Walker Bullet is 5'3". I have done 360's on a 5' Comp X as well.
06-24-2009, 10:18 PM
The landlock can take a heavy rider, but you are definitely pushing it. One thing to try, is move your feet foward on the board more, as much as 6 inches to a foot, you have to get that nose down to "catch" the wave. I have used the landlock to teach many people, and I have noticed, that when someone who is heavier rides, the nose is up in the air, and they can't get the wave to push them, or catch the wave. I usually have those people move more forward on the board than I would have anyone else ride, and it many times solves the problem. Anyway, I had some footage of a couple of bigger dudes on the landlock behind my boat, so I put something up for you. May help. http://wake9.com/blogs/how-to-wakesurf-101/2009/06/24/quick-help-big-guys-wakesurfing-on-the-landlock/ I just posted the video, may take a few minutes for YT to process.
06-25-2009, 6:42 AM
Collin--- I an 289 pounds and I use a Inland surfer blue. It is a great board for big, small, beginner or advanced. you should try one.
06-25-2009, 11:11 AM
Thanks for the tips! Looking at the videos my feet are back farther so I will try and scoot forward. If that doesn't work I will start looking for another board
06-25-2009, 1:06 PM
^^^ Do the latter part of that anyway.
