Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through June 28, 2009
Old     (naptownwake)      Join Date: Jul 2007       06-20-2009, 9:42 AM Reply
Can't find the ol wire brush, I'm tempted to try out the neighbor's pressure washer.
is this too harsh on the wood?
(Message edited by naptownwake on June 20, 2009)
Old     (chpthril)      Join Date: Oct 2007       06-20-2009, 9:54 AM Reply
Nope, not at all, just use one of the wider angle nozzles.
Old     (naptownwake)      Join Date: Jul 2007       06-20-2009, 10:41 AM Reply
thanks!
is there a certain width measurement I should shoot for?
if they only have one narrow nozzle, should I just go get another wire brush and go old school?
Old     (kirk)      Join Date: May 2003       06-20-2009, 11:45 AM Reply
Use at least a 25 degree and don't hold it too close or it will mar the teak.
Old     (hatepain)      Join Date: Aug 2006       06-20-2009, 11:56 AM Reply
How many PSI is the washer? If it's under 2k you should be fine if you dont hold it to close to the deck with either tip. The highr PSI ones your chancing getting some "burns" in the wood.
Old     (rallyart)      Join Date: Nov 2006       06-20-2009, 12:25 PM Reply
No. Pressure washers are great for sealed surfaces but not for open grain like teak.
Don't use a steel brush either. You could use a BBQ brush with brass or bronze bristles, or Bronze wool, or maybe stainless steel wool if you had to
