Some of this sounds like how you are throttling it at start. As you get close to the set speed when getting on plane, start backing off the throttle manually a little so that you do not overshoot the speed. If you over shoot it too much, it will over correct, but eventually it should get dialed in. If this is not the problem, you can also adjust the settings on how fast the PP computer adjusts speed and if you call PP they will help you out. This is one company that has awesome customer support.
