yup, yellow impellers and a little lube and you should be good to go. I had the same problem everytime out for about a year. Switched to the yellows a few years ago and it hasn't happened once. As a temporary fix, flip to empty as soon as you are done filling and vice versa. If you flip the impeller while they are still wet it usually works a lot better.
