Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through June 28, 2009
Old     (extremeisaac)      Join Date: Aug 2005       06-17-2009, 4:07 PM Reply
Anyone know the dimensions of the rear storage lockers of the V210? curious if the fly high twin 400s will fit back there 42"x16"x16"
And with them loaded is there still room to throw some life jackets on top of them or will they take up every bit of room?
Old     (airrantz)      Join Date: Jun 2004       06-17-2009, 7:23 PM Reply
I have the fly high V-drive sacks in my V210 and they fill up no problem. You can fit a few life vests in there as well. Are you getting them for surfing, boarding, or both. If you're only looking to wakeboard I doubt you'll ever need all 400lbs because the boat likes to be front weighted but for surfing they're the perfect sacks. If I got someone who wants a huge wakeboard wake I fill them about half full with 1000lbs+ up front and a couple people in the boat.
Old     (extremeisaac)      Join Date: Aug 2005       06-18-2009, 1:24 PM Reply
Ryan, I have the front locker bag currently plumbed in, nothing in the back.. wake is decent.. not as big as I would like.. figured adding in 400 in the rear would make it perfect with the 400 in the front locker full?? any insite?
Old     (ralph)      Join Date: Apr 2002       06-18-2009, 1:44 PM Reply
Personally I would put 700 in the front before putting anything in the rear. After getting 700 in the front I would start adding front to rear weight 1:1
But we normally ride 4-5 peeps so you need to take that into consideration as well.
Old     (guido)      Join Date: Jul 2002       06-18-2009, 1:52 PM Reply
Isaac... 250 per side in the rear and another 500 sac on the floor in the walk through. That should get you to proper status.
Old     (extremeisaac)      Join Date: Aug 2005       06-18-2009, 1:56 PM Reply
so.. 5-700 on top of the factory 400lb sac in the front locker? or total?
Old     (ghostrider_2)      Join Date: Aug 2004       06-18-2009, 2:05 PM Reply
Yes that is what Evan means. Sangerslove weight in the nose. Shamless plug .I have a 600lbs fat Sack I need to unload.
Old    walt            06-18-2009, 2:11 PM Reply
Put 2000 to 2200 pounds in her and the wake will be great. I agree with the other guys that the V210 likes most of the weight up front.
Old     (airrantz)      Join Date: Jun 2004       06-18-2009, 4:05 PM Reply
Isaac throw another 500lbs in the walk thru and you'll enjoy the wake. No need to add weight in the rear unless you want to really slam it and run a little longer and faster then ask Walt or Darren where to put it, I've seen pics and they look dialed in. Most of the time I run a custom ski locker sack full till the lid comes up (debatable how much weight probably 400+) and 400lbs of pop bags in the bow with 4-5 people it's perfect for me and you have tons of storage to boot.
Old     (extremeisaac)      Join Date: Aug 2005       06-18-2009, 4:20 PM Reply
So your saying run just an additional 500 in the bow/walkway and nothing in the rear?
Old     (airrantz)      Join Date: Jun 2004       06-18-2009, 4:24 PM Reply
Yeah do that and see how you like it. Then if you need more start adding some to both the front and rear at a 1:1 like Darren suggests. 400lbs of pop products bags were the best investment I've made. I keep 160lbs up front under the seats full time (wake/surf/tow) and move 240lbs to the walk thru for wakeboarding or under the surf side seats for surfing. Weight up front also makes the boat ride through chop like a dream.
Old     (wake_upppp)      Join Date: Nov 2003       06-18-2009, 4:44 PM Reply
"on top of the factory 400lb sac in the front locker?" Isaac, 400 is probably about a hundred pounds on the over realistic side.
Old     (wake_upppp)      Join Date: Nov 2003       06-18-2009, 4:59 PM Reply
Isaac 42" is going to be too tall I think. I did custom FlyHigh sacs in the rear lockers in my 06 210. Dimensions are 31"L, 16"W, 15"H. Takes up the space perfect and leaves about 6" above the sac to still store stuff. I run those full and the stock front bag, and an additional 250 in lead under the front cushions. I also have a 500 for the walkway that I rarely use because at 23.5 it's just fine and still pretty easy on fuel, and no sac to climb over.
Old     (extremeisaac)      Join Date: Aug 2005       06-18-2009, 5:37 PM Reply
Sparky how big were teh custom sacs you had in the rear?
Old     (rio_sanger)      Join Date: Apr 2007       06-18-2009, 7:00 PM Reply
"400lbs of pop products bags were the best investment I've made." I keep 160lbs up front under the seats full time (wake/surf/tow) and move 240lbs to the walk thru for wakeboarding or under the surf side seats for surfing. Weight up front also makes the boat ride through chop like a dream."
...pretty much what we do as well
Sangers love the weight in the bow!
The weight of the engine in the rear of the boat really doesn't need much more help...
