Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through May 06, 2009
Old     (lfrider92)      Join Date: Sep 2008       05-05-2009, 7:23 AM Reply
I want to try a 360 at the lake this weekend.
any tips? never tried a handle pass
Old    trevor_kershaw            05-05-2009, 7:34 AM Reply
dont rail into the wake, take a nice easy edge and then give it alittle more at the wake so it pops you up. pop off the wake and then pull with both hands, dont spin off the wake or you can get pulled off.
Old     (jarrod)      Join Date: May 2003       05-05-2009, 7:34 AM Reply
Find the I love 360s thread. This was just discussed. Or look in trick tips.
Old     (eubanks01)      Join Date: Jun 2001       05-05-2009, 7:52 AM Reply
J-Rod's got it. Look in the trick tips section and there are a bunch of 360 threads with good input.
Old     (bzager)      Join Date: Apr 2009       05-05-2009, 8:05 AM Reply
just make sure u pull the handle with BOTH hands towards your trailing hip before you go for the pass otherwise youll never get the handle again!
Old     (lfrider92)      Join Date: Sep 2008       05-05-2009, 8:17 AM Reply
ill check that thread. but dumb question. ive seen pictures and videos of riders taking off with the handle behind their back. would that make it easier since there is no handle pass? or is that more advanced?
Old     (wakeborder5)      Join Date: Jun 2002       05-05-2009, 8:32 AM Reply
Thats called wrapped and might be easier, I actually learned the 3 that way, but most learn the handle pass 3 before wrapped, you can prolly eat more the wrapped if u dont make it all the way around as well as greater chance of going off axis
Old     (lfrider92)      Join Date: Sep 2008       05-05-2009, 8:37 AM Reply
okay ray, thanks. it just looks like it would be easier. i know some people that can do wrapped tricks and cant handle pass. i guess it cant hurt to try both. well it could, but i hope it wont. *laughs*
Old     (lfrider92)      Join Date: Sep 2008       05-05-2009, 8:52 AM Reply
one more question. when taking off. where should my hands be on the handle. when im just jumping my hands are all the way in and together. and i doubt thats right
Old     (dizzyj)      Join Date: Jul 2003       05-05-2009, 9:04 AM Reply
it dont matter. I ride with my hands together at all time. If you cant make the handle pass with your hands together, your not going to make it with your hands appart.
Old     (wakedad33)      Join Date: Oct 2005       05-05-2009, 9:49 AM Reply
Wear a helmet
Old     (wakerider111)      Join Date: Jul 2006       05-05-2009, 12:59 PM Reply
"pull-pop-pull, pass"
Old     (behindtheboat)      Join Date: Aug 2006       05-05-2009, 1:20 PM Reply
If you have a good sized wake try going from inside to outside the wakes to try and get the idea of handle pass and body position.
Old     (mikegh)      Join Date: Jun 2007       05-05-2009, 2:45 PM Reply
Agreed. Also, learn them on the surface at around 15 mph. Try that, then inside-out, then 1 wake, then wake to wake. And pay special attention to the 2nd half of the trick when you're on the surface, the switch toeside backside 180 (assuming you're talking heelside frontside 360)
Check out learnwake.com if you can.
Old     (wswb4lfe)      Join Date: Jan 2009       05-05-2009, 2:50 PM Reply
Handle to the hip at all times
