Old     (cbennett224)      Join Date: Mar 2009       03-18-2009, 6:29 PM Reply
I have a custom built 6.5" speaker enclosure for my tower, and I am trying to figure out what would be the best amp. I was thinking of the cadence TXA150 2 channel amp. But in every description I have found on it, it only talks about using subs, so I am a little confused?
Any advice would be great!!!!
Old     (my_malibu)      Join Date: Feb 2008       03-19-2009, 11:10 AM Reply
will work fine its even 2 ohm stereo stable
cadence"s old line only draw back is there size
hook it up enjoy the music
Old     (gborgh)      Join Date: Aug 2008       03-19-2009, 9:46 PM Reply
I have a txa 600.4 that I use to power a set of NVS deviants. Briged it will easily overpower the speakers if you want. I have looked at the txa 150.2 as an amp for a sub. I agree with craig that they are big. Another issue is making sure it gets good ventilation since it does not have an internal fan. I mounted an external fan to blow on my amp that I control off a seperate switch. It is only an issue when you are really cranking the music. That is a good amp and you can get them really cheep. I would get the TXA 300.4 and bridge the other two channels to a sub. This also gives you plenty of power in case you upgrade your speakers in the future. The TXA 300.4 can run 300 rms@4 x 2 ohm which is enough to power even the high end equipment if and when you upgrade. Go to www.cadencestore.com txa 150.2 is 99 with free shipping and the txa 300.4 is 129 with free shipping. You will be happy with the purchase.
