Old                05-04-2003, 10:06 PM Reply
Ive got t/s wake 2 wake and 180s but i want a more lofty jump t/s... i cant seem to get a good progreeive edge t/s does any one have advice on what to do to take a good edge t/s and a comfortable way to do it...
Old     (davidbouvier)      Join Date: Aug 2002       05-05-2003, 8:00 PM Reply
make sure your t/s edge is nice and progressive. wait until the rope starts to pull you back in. then start to make your cut. nice and mellow at first. then lean into it right before the wake. Don't try to cut too hard too early. you have to ride your edge all the way up the wake. this will keep your body in position over your board. If you find your getting pulled around by the boat and hte board going out in front of you, it's cuz you let off your edge. hold the handle with both hands until your just ready to land. Give a little extra pull with your trailing arm toward your rear hip. like, pull through your shoulder blade. not your bicep. hope this helps a bit.
