I bought a pair of these last week and just received them today. They are very comfortable and I think they could be great bindings, but I am experiencing some heel lift from the base plate. With the boots mounted on my board (2007 Shane) if I lean forward the heel of the plate will raise up about a 1/4 inch. To try to eliminate this I used some shorter screws to make sure the screw wasn't hitting the bottom of the hole and leaving some room for flex. This isn't the case; the plates are locked down as tight as possible. It's the base plate itself that is flexing, allowing the heel to lift up. Has anyone else experienced this with their Gonzales boots?
