The fogging oil should be run into the motor, thru the carb, while the motor is running.Simply run the motor at a high idle speed, and spray the fogging oil into the carb. bores.The general rule of thumb is about 1 minute of spraying per cylinder, so you want about 7-8 minutes of fogging oil sprayed into a running motor.
