Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through December 15, 2008
Old     (analdine)      Join Date: May 2006       10-21-2008, 7:11 PM Reply
Anyone ever tried this? I have amp for deck and amp for tower, I was just thing of bridgeing front and rear for bow.....
Old     (brit_rider)      Join Date: May 2004       10-22-2008, 7:25 AM Reply
You cannot bridge channels on a HU - The amp is already running at its max capacity when powering a 4ohm load (Though you can run multiple speakers per channel by sharing the wattage over them - you'll not really gain much there though).
Old     (analdine)      Join Date: May 2006       10-22-2008, 1:58 PM Reply
Yea thats what I thought...I have some awesome speakers up there but hate to waste an amp. on two 4ohm speakers.
I would need 300-400 watt amp to get 75 watts at a 4 omn load
Old     (hamkj)      Join Date: Apr 2002       10-22-2008, 7:46 PM Reply
YES... YOU CAN BRIDGE A HEAD UNIT BUILT IN AMP!!!
Go find yourself a head unit that has the bold print on the face plate... 4x50 watts.
Then bridge it... 2 x 100 watts
Then take your two speakers... positive to positive and negative to negative... twist together and connect!!!!
You should be pumping 2 x 200 watts... or even better... add another two pairs and drop your impedance to 1/2 ohm...
You should be able to get close to 500 watts out of that bad boy...
Might out power your sub and tower speakers... but it will kick a$$!!!
After you do it... post on here and let us know how it all worked out...
Best of luck!
Old     (formulad97)      Join Date: May 2007       10-22-2008, 8:02 PM Reply
^^^^^^^^^^ HAHAHAHAHAHHAHA ^^^^^^^
Old     (cavlxenvy)      Join Date: Aug 2007       10-23-2008, 5:27 PM Reply
that is so cruel.
