Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through October 06, 2008
Old     (mrdenial)      Join Date: Sep 2006       09-14-2008, 2:44 PM Reply
I have a 2001 Tige 21v with vibration that I can feel in the steering wheel and throughout the boat at low RPM.
Basically, as I'm pulling away from the dock and give it a little throttle, the boat shakes. RPM up or down from there and it goes away. Had a few small dings in the prop, so I changed that out and it's still the same.
Thinking it's the shaft?
Old    alanp            09-14-2008, 2:49 PM Reply
shaft or bent strut
Old     (chpthril)      Join Date: Oct 2007       09-14-2008, 3:24 PM Reply
With the age of your boat, I wouldn't rule out a misfire, low RPM acceleration puts the most load on the ignition system. How many hours
Also check the trans fluid level.
(Message edited by chpthril on September 14, 2008)
Old     (mbouchard)      Join Date: May 2006       09-15-2008, 5:39 PM Reply
We've seen some props go out of alignment with age at the shop - and even though you could not visually see anything - a $80 rebalance could do wonders....
