I have found that in I/O's you really want to put most of the weight up front. The other day we rode behind a buddies 21ft caravelle and I put 600lbs front, on the walkway floor a 370 with a 250 on top of it. and another 400 on the floor right in front of the back seat. Then we trimmed the motor up about a 1/4 from all the way down and the wake was pretty good. Just had to ride a little shorter rope at 21.5 to make everything balance out. I don't know about trim tabs, but I would say that you should put them all the way up so that they aren't really doing anything. Every boat is diff. You will have to play with the speed, rope length, and weight distribution to get it dialed.
