Here is what I do: Buy some clear vinyl hose from the hardware store. Get the hose that is just about the size of the opening to the gas can. Cut is about 3-4 ft in length. Put the gas can on top of your engine cover, or somewhere where the bottom of the gas can is higher than your boats gas cap/input. Stick one end of the hose in gas can so it goes all the way to the bottom of the can. Stick the other end in your boat's gas tank/input. Make sure the vent is closed on the gas can. Place a rag around the hose that goes into the gas can, to seal off the gap between the hose and the gas can opening. Make it air tight. Squeeze the gas can. Watch the gas go up the hose, then down into your boat. Once the gas is flowing, take away the rag and undo the air vent. The can will drain in about 30 seconds and you won't spill a drop of gas. If you do it right, you will be able to syphon about 90% of the gas. The rest you will have to pour the old fashon way using your ghetto spouts. Since it will be just a small amount of gas, your spouts won't bug you. I have done this for years. It works awesome. I have a Malibu. Some boat's gas input is not large enough for the size of hose you need to make this work well. When you do this, make sure you are not close to being full. The gas comes out really fast, and it will back up if your tank is too close to being full. You can buy gadgets to do this - but the home grown method works best. My buddy learned this from guys in Hong Kong who bought gas on the black market. I figured I would pass onthe type.
