Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through August 19, 2008
Old     (blake_hughes)      Join Date: May 2004 Location: Weatherford, Texas       08-16-2008, 3:03 PM Reply
I just bought a 01 Mastercraft X-Star, and found out that the fuel gauge doesn't work properly.
The problem: Regardless of the tank level, the gauge reads full.
I found a similar thread, which mentioned something about the ground wire. I tried using a better ground, but the gauge still reads full (with 3/4 tank).
Any help, or suggestions?
Thanks!!!
Old     (krbaugh)      Join Date: Mar 2002       08-16-2008, 3:42 PM Reply
you most likley need a new fuel sending unit
Old     (blake_hughes)      Join Date: May 2004 Location: Weatherford, Texas       08-16-2008, 3:54 PM Reply
This 'supposedly' is a new sending unit.
The people I bought it from replaced the sending unit, but was never able to make it work properly.
Old     (headhunter)      Join Date: Jun 2007       08-16-2008, 3:57 PM Reply
Float might be stuck also.
Old    K.B.C.            08-16-2008, 4:06 PM Reply
same thing happens to my friends X-1. Reads full until it's about half empty. I think it is actually a common problem with these boats for some reason. I have heard of this issue numerous times now. I think you may just have to live with it
Old     (blake_hughes)      Join Date: May 2004 Location: Weatherford, Texas       08-16-2008, 4:08 PM Reply
I thought about pulling the sending unit out, to see if that was a possibility. I didn't because I wasn't sure about the tank/sending unit gasket. It appears to be a rubber gasket only. Does that sound right, or should I go buy some liquid gasket 1st?
Thanks!
Old     (krbaugh)      Join Date: Mar 2002       08-16-2008, 4:13 PM Reply
It is no big deal just pull it out the gasuket will be fine. if it is the kind with a float you can move it up and down and watch the gauge. MasterCraft was using a none mechanical gauge that had no float
Old     (blake_hughes)      Join Date: May 2004 Location: Weatherford, Texas       08-16-2008, 6:04 PM Reply
I pulled the sending unit, and was able to get different readings by alternating the depth of the pickup.
Looks like you're right Scott...
Thanks for all the help!
Old     (aussie_stu)      Join Date: Sep 2002       08-16-2008, 10:13 PM Reply
could be a mis-matched gauge/sender, if you wanna really dig into it, take the gauge and tank sender to an auto electrician and get them to test the ohm range of both, if they are not the same rnage the gauge will read a bit off.
Old     (krbaugh)      Join Date: Mar 2002       08-17-2008, 4:16 AM Reply
it could also be the wrong length send unit for the tanks
Old     (driving)      Join Date: Jan 2003       08-17-2008, 5:17 AM Reply
Have you tried adjusting the gauge? There are two little screws on the sending unit that you can turn to adjust how it reads.
