Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through August 21, 2008
Old     (bendow)      Join Date: Sep 2005       08-08-2008, 5:53 AM Reply
I'm 6'1" and 170lbs. I usually ride a shane 140, but found a good deal on a 136. Is a 136 probably too small for me?
Old     (bendow)      Join Date: Sep 2005       08-08-2008, 6:52 AM Reply
c'mon fellas. I need some opinions soon...
Old     (glee22)      Join Date: Jun 2008       08-08-2008, 6:56 AM Reply
check out the weight chart
Old     (skelley19)      Join Date: Aug 2008       08-08-2008, 6:58 AM Reply
I'm 5'11 170 and i ride a PS3 137 and love it although i would like to see how the 141 works for me. I sometimes ride my buddies Witness 140 and that seems to pop me a little bit higher but that could be the board design more than the 3 cm size difference. hope this helps
Old     (eas)      Join Date: Nov 2001       08-08-2008, 7:18 AM Reply
No....not too small but all personal preference.
I'm a little bigger than you and ride a 134 Watson....if they made a 136, I would ride it....but I won't ride the 138 for now. Again, personal preference. I came off 139 and 140 boards and wanted to see what I could do with the shorter board. Also, as boards get wider, length becomes less of an issue.
Old     (migs)      Join Date: Aug 2006 Location: SF Bay Area       08-08-2008, 8:28 AM Reply
too small. for sure.
Old     (pfort)      Join Date: Mar 2007       08-08-2008, 8:30 AM Reply
The 08 Shane is a little wider then the 07 board so it rides bigger then most 136 boards. I am about the same weight, but 5'9 and like it. It is personal preference. I know guys smaller then me that ride 140-141.
Old     (hyperliteguy_04)      Join Date: Jun 2007       08-08-2008, 8:31 AM Reply
Im 5'7 150lbs and i ride a 07 hyperlite state 140
Old     (steezyshots)      Join Date: Feb 2008       08-08-2008, 9:44 AM Reply
My wife weighs 105 pounds and she rides a 136. You should be on a bigger board. But then again it is all preference.
Old     (wakeriderixi)      Join Date: Jan 2004       08-08-2008, 10:14 AM Reply
I wouldn't, just my opinion based on my preference.
Old     (bendow)      Join Date: Sep 2005       08-08-2008, 10:18 AM Reply
Yeah…I guess I’ll save up a few more pennies and get another 140. I’ve had such a rough time with boards this year. I’ve broke 3 shanes and got one stolen when my car got broken into. This will be my 5th shane in 08…it’s killing me.
Old     (migs)      Join Date: Aug 2006 Location: SF Bay Area       08-08-2008, 10:23 AM Reply
any problems ive had with my LF's they send me one no charge - no questions. You should give em a call if youre breakin your decks.
Old     (hawkeye7708)      Join Date: Feb 2007       08-08-2008, 10:23 AM Reply
I'm 6'1 and 185 and I rode a 136 Premier and loved it. Upgraded to a bigger board becasue i'm really working on going bigger and the landings were getting SLIGHTLY not fun, but its definitely doable.
Old     (kcrider)      Join Date: Jul 2008       08-08-2008, 10:24 AM Reply
Have you tried the limited edition shane with the grind base. I have the limited PS3 with the grind base and I think it holds up a little better. Its heavier but seems to take more of a punishment. Maybe you won't break that one. Just a thought. I ride my limited at the cable park.
Old     (kcrider)      Join Date: Jul 2008       08-08-2008, 10:25 AM Reply
Never mind I forgot the limited was a 136. Cancel my last post.
Old     (bendow)      Join Date: Sep 2005       08-08-2008, 10:30 AM Reply
Can’t warranty a board if it’s seen a rail.
I’d love to have the grind base, but they only come in the 136 (which really sucks). I ride cable a lot, but a lot of my boards break more from impact than rails.
Old     (steezyshots)      Join Date: Feb 2008       08-08-2008, 11:20 AM Reply
If you're just riding cable you could get away with a 136. I was thinking boat and taking hard landings with a small board.
I usually ride a 142 but when i go ride cable i shorten my board up to my 139. And Im 6 foot 220lbs
Old     (sidekicknicholas)      Join Date: Mar 2007       08-08-2008, 11:26 AM Reply
6' 180 and rode 132/134's until just recently...
only went bigger because of it being a slingshot
