Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through August 21, 2008
Old     (sk24iam)      Join Date: Jul 2008       08-07-2008, 3:32 PM Reply
I have LF domain bindings on LF trip and for my bindings move a little bit after every run. For some reason, they don't get very tight. Any suggestions before I call LF?
Old     (scott_a)      Join Date: Dec 2002       08-07-2008, 3:35 PM Reply
loctite
Old     (andy_nintzel)      Join Date: Sep 2004 Location: Minnesnowda       08-07-2008, 3:49 PM Reply
That's because you are using "THUMB" screws! Go get some 1/4 - 20s at the Hardware store and you are set! Bring a thumb screw so you know what size to buy, then buy a nice #2 Philly!
Old     (duffmangt)      Join Date: Jan 2008       08-07-2008, 4:23 PM Reply
ive had 3 of the thumb screws fall out on me while im in the middle of a session...it sucks and LF should just stop using them
Old     (sk24iam)      Join Date: Jul 2008       08-07-2008, 8:19 PM Reply
Here is as tight as they get...
http://www.youtube.com/watch?v=MlwC6RdPZqI
Old     (wakemitch)      Join Date: Jun 2005       08-07-2008, 8:38 PM Reply
SK, those ones actually have too much loctight on them. take a blade to them and get some off. you will be able to get them on all the way tight.
ive seen some boots with this issue.
that plate wont be used next year.
Old     (sk24iam)      Join Date: Jul 2008       08-07-2008, 9:07 PM Reply
Is loctight the metal screw part? What do I use to cut it?
Old     (wakemitch)      Join Date: Jun 2005       08-07-2008, 9:19 PM Reply
SK, its the blue stuff on the thread of the thumb screw. use a razor blade and peel it off.
Old     (sk24iam)      Join Date: Jul 2008       08-08-2008, 8:09 AM Reply
I don't see that much loctight on my screws to being with. Should I take it all off?
I called Liquid Force and explained to them the problem and they said that is a common problem and the solution is to upgrade to the transit bindings. It would have been nice if they sent me a better hardware set.
Old     (wakemitch)      Join Date: Jun 2005       08-08-2008, 8:11 AM Reply
sk, yeah just take it off. just double check to make sure their tight before each set, but they should be fine.
