Old     (99_air_warrior)      Join Date: May 2008       06-30-2008, 7:53 PM Reply
Can anyone help me weight my boat with ballast It has a 30 gallon tank from the factory in the rear above the gas tank. I put two bags along the direct drive engine they weight 240 lbs. each . I put 500 lbs. on the bow in between the seats under the window. it still doesn't much of a wake. Any help I would be very thankful Joe
Old     (silverwake)      Join Date: May 2007       07-01-2008, 6:17 AM Reply
Hi Joe,
Check out www.centurioncrew.com
they might be able to help
Old     (bmartin)      Join Date: Jan 2007       07-01-2008, 8:12 AM Reply
Sounds like you need to add or shift some significant weight to the rear, especially considering it is a DD. We weight our v-drive Lightning (similar hull) with about 600-1000#s rear, similar center tank, and about 400#s in bow and move people around to tune the wake. Good luck. You can get a decent wake, just need to experiment.
