few things, when you put a new alternator on always replace the belt, if the pulley looks different, change the pulley with the original one. with a new alternator and belt it shouldn’t make a squeak, the alternator will have holes for mounting, the adjustment is on the bracket, unless you have something else on the same belt, then the adjustment will be on that.
