Mike, those JL amps pull a ton of current. The regulated power supply in them amplify the problem ( They still put out same power regadless of voltage input) Do the math in ohms law. How long are your wire runs? from amplifier to fuse? Do you have acess to amp meter? All else fails run to your local welding shop and pick up some bigger cable.
