Hey Sean, Bet you are going crazy trying to re-thread the lock down devise. The trick is to take a flat head screwdriver and pop off the lock down thing. It comes right out. Then you can re-thread it and pop it back on. Tie a good knot at the end of the string when you are done. Then re-tie your other boot or it will be coming undone next. If you need more info search this forum. There are threads with pictures and knot tying advice for this common problem. -Bob
