Old     (wakeboardmatt)      Join Date: Jun 2007       07-22-2007, 10:39 PM Reply
It is not the greatest boat but it is all i have got. Seeing as this is the situation i usually hitch a ride with friends. I would like to be able to ride more on my own boat. Any recommendations for making this more wakeboard friendly?
also, we are going to buy a tower, any recomendations?
Old     (wakeprodigy)      Join Date: Oct 2002       07-23-2007, 5:07 AM Reply
If you do put a tower on this boat make sure to reinforce your fiberglass around the mounts. These boats were not designed to have a tower mounted to them and they cannot support the force that is applied to fiberglass. If you install a tower without reinforcement it will most likely be pulled through the fiberglass and could cause serious damage to your boat and/or injure a passenger. Just wanted to give you a warning before you go and drill holes in your boat.
Old     (wakeboardmatt)      Join Date: Jun 2007       07-23-2007, 5:36 PM Reply
Oh yeahh for sure, we would reinforce the hell out of it lol. Any ideas for a better wake? steeper, larger etc.
Old     (wakeboardmatt)      Join Date: Jun 2007       07-24-2007, 6:26 PM Reply
I really want to put sacs in it but my dad says that we cant put sacs in it because it is not designed for it. If i put sacs in it would it cause problems? or would it be just fine?
Old     (wakeprodigy)      Join Date: Oct 2002       07-24-2007, 7:15 PM Reply
It should be fine with fat sacs. For example if you get a 600lb fatsac that's basically the same as having 4 people in the boat. The only difference you will probably notice in boat performance is that it takes longer for the boat to get on plane. From what I've heard most I/O's respond best with the added weight in the bow and then also trim up a bit.
Old     (wakesetter101)      Join Date: Oct 2005       07-25-2007, 5:02 AM Reply
Fat sacks dont help any boat as far a wear and tear. But you will be fine.
Old     (wakeboardmatt)      Join Date: Jun 2007       07-31-2007, 10:11 PM Reply
What do you mean the dont help wear and tear, i am not trying to help wear and tear
