Is there sound coming out of any of your speakers? Are all of your speakers amped, or are any ran directly off you deck? Is your amp turning on, did you run your remote wire for the amp? When you measure voltage of the speaker outputs(amp or deck) is you DMM on AC or DC volts? A common problem that I see with alpine decks is this: If you are running speakers off the deck, if any one of them shorts out, you will get no audio period. Also on the same note, if your speakers are all amped, you need to make sure the speaker wires on the radio harness are all capped properly so they don't short together (causing the same problem as a shorted speaker) Alpine puts out some good stuff and if you have a new deck I highly doubt that the deck is the problem. Keep it in mind, but I would consider that your last option.
