Old     (zeus12)      Join Date: Jun 2006       07-16-2007, 7:22 PM Reply
running stock ballast, 2 550's in the back and sometimes a walkway sack depending on how many people are in the boat (usually 5-7).
What are you x2 owners setting your KDW and NN at?
Also,
Has anybody ever had to change the CS?
Old     (jarabacoa)      Join Date: Aug 2002       07-17-2007, 5:31 AM Reply
I am not sure if our versions are the same, but for my 07'
CS-900
NN-120
KdW-190
I am running around 2400 lbs with just a driver.
Old    willytown12            07-17-2007, 9:49 AM Reply
thanks Jarabcoa. Mine is having some trouble grabbing so I figured i would see what everybody else is set at. Any others have input?
Old     (c640947)      Join Date: Jan 2005       07-17-2007, 10:00 AM Reply
i will try to remember to check mine. There is a setting for how much it overshoots before it engages and that seemed to be one of the keys for mine. Its at the max. I ride 2500+ ballast.
Old     (zeus12)      Join Date: Jun 2006       07-17-2007, 2:34 PM Reply
Sometimes it doesnt grab at all. I am still troubleshooting. the guys at pp are great to deal with. Any other advice?
Old     (saroberts70)      Join Date: Aug 2006       07-17-2007, 3:43 PM Reply
Zeus. Are you having trouble holding speed? I've tried 2 400# bags in the back of my X-30 along with the stock ballast and my PP cannot hold a constant speed at around 23 mph. If I put 400-600 in the front all problems stop.
Old     (jarabacoa)      Join Date: Aug 2002       07-17-2007, 5:21 PM Reply
The key to mine is to make the boat overshoot the speed, just a little, so when it backs down, it does not go below the intended speed. From a stand still, I always go 90 degrees from neutral and it works great. Mine used to engage early and never really got to speed.
Old     (zeus12)      Join Date: Jun 2006       07-17-2007, 5:27 PM Reply
Holding speed is not the issue, When it grabs it overshoots a little, which is expected. The issue is when it doesnt grab at all, as if its not engaged. Everything on the gauge is reading correctly, rpms and speed, it just doenst grab and accelerates right through the set point
Old     (louie)      Join Date: Jun 2006       07-17-2007, 6:29 PM Reply
Up your KDW by 5 on the perfect pass until the problem stops.More weight more KDW.
Old     (c640947)      Join Date: Jan 2005       07-18-2007, 10:03 AM Reply
to clear it up, is it overshooting (which it should by a bit), engaging and then falling so far to unengage and then won't get engaged? Or simply doesn't catch sometimes?
check to make sure you cables are TIGHTLY connected to your battery. that was my problem (we think.)
Old     (zeus12)      Join Date: Jun 2006       07-18-2007, 10:28 AM Reply
it is just not engaging sometimes, never catching
(Message edited by zeus12 on July 18, 2007)
Old     (jarrod)      Join Date: May 2003       07-18-2007, 12:14 PM Reply
Zeus. We just had troubpe with our X-Star doing the same thing, but only, it never engaged at all. We had minor faulty wiring that one day in the shop fixed.
Old     (zeus12)      Join Date: Jun 2006       07-18-2007, 12:34 PM Reply
whats interesting is the control test works every time.
Old     (boarder33)      Join Date: Jan 2006       07-25-2007, 7:55 AM Reply
Can someone tell me what each of them do?
CS-900
NN-120
KdW-190
Old     (brttkrz)      Join Date: Aug 2005       07-29-2007, 10:29 AM Reply
how do you get to the cs setting on the 6.5 version?
