Yesterday I went wakeboarding and came in hard toeside and made it across the wake and caught and edge and got my balls slapped. I came up wincing in pain and then i went again and it happened again. Is there something I'm doing wrong(handle position, landing position, etc.)?
wear a life jacket upside down like a diaper...you're pals should be protected then
i found that really planting the handle to the lead hip helps a TON! stand up tall when you pop off the wake. try and land edging away from the boat a little.
Go to the hardwarde store and get some foam padding, you know the kind that looks like an egg carton, just cut to fit and wrap them around your boys, if that doesn't work you can always go with the bubble wrap.
Worry more about your technique than ball slapping. It happens to everyone, it's part of the game. If you can't get over the fear of slapping your balls, you have a lot more to worry about than not being able to go toeside.
For the record, I've never seen anyone wear anything under their boardshorts and they are anything but rooks.
