Yah know the plugs that are in the block??/ They look like they are brass and never needed for anything...simply holes in the block that are plugged...then the block is coated during marinization....I had one go-front..right side...just under the front right motor mount...causing a giant water fall into my engine compartment, and filling up the entire back of my boat...barely making it back to the marina...and pretty much beaching her on the launch...then pulling it out ... now..water int he oil and everything...I had run her for the first time this year,,,ran fine...pulled it out..changed the oil..put it back in...idled for a while..checked everything..then..ran nice and progressive...starting slow and then ramping it up as it warmed up to about 30 mph for a while...still all good...then up to 40 mph...all good...then the engine temp started shoeing really low....then the auto bilge went on...I slowed down to check....upon opening the engine hatch...water water water...then limped it back to the dock!!! that plug blowing.....is that waruntee...as it seems to me to look like something that should never go..as being as...it was running fine and dry for the initial period...it was something that went as the motor heated up..??? COMMENTS FEEDBACK
