Less running gear in the water and no thru-prop exhaust gives the prop better bite, and makes for a cleaner wake. As said, the hull is designed not to plane out, so you sacrifice top speed and economy at higher speeds (as if those matter, and a 2 stroke outboard will have poor fuel economy too). There's also a learning curve to docking an inboard, but you pick it up pretty quickly. The only circumstances I'd consider an outboard would be if I ran in saltwater all the time. I/O's are a decent compromise, but I'd be willing to bet you haven't spent much time in / behind an inboard.
