Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through April 09, 2007
Old     (showtime)      Join Date: Nov 2005       04-02-2007, 6:44 AM Reply
i'm adding a bag in the frt locker of my 00' Supra Launch. the boat has rear ballast from the factory. any reason why i can't just tap into it? the pump isthreaded directly into the thru-hull, plans are to remove, basically add a tee and secure both pumps (will only run one pump at a time) ? is what size and hard or soft pipe/hose all the way to the frt? figured i'd tie into the bilge for vent and drain back to the rear discharge. this way no more holes have to be drilled....i know this is a litle scattered -- - would you fill the sac from the bottom or the top? does it matter.
