One of those garage lamps you hang on car hoods to work on em. Should keep more than enough heat in the bay if you have power to your shed. If not, there should be a drain under the block on both sides, and you need to disconnect any hoses and drain them out as well. You could drain your exhaust manifolds as well, but they probably won't get full enough to need it.
