Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through April 09, 2007
Old     (lrbs_xstar)      Join Date: Mar 2007       03-31-2007, 7:27 PM Reply
ok i bought a 2001 xstar and 2day was the first time taking it out and when i went to turn the radio on the stereo lighted up but there was no sound?When i test drove it everything worked properly!The dealership winterized it for me so is there anything they could of done that could be causeing this problem?
Old     (05mobiuslsv)      Join Date: Apr 2006       03-31-2007, 7:34 PM Reply
If you have a perko switch make sure it's switched to both. Maybe you're amps are hooked to your other battery and it's isolated so you have no power to them.
Old     (lrbs_xstar)      Join Date: Mar 2007       03-31-2007, 9:00 PM Reply
there is only one battery and whats a perko switch?
Old     (99_slaunch)      Join Date: Oct 2005       03-31-2007, 9:08 PM Reply
A perko switch is used to isolate you're battery. Most all amps have a little led light that indicates the amp is on check that.
Old     (fuller313)      Join Date: Oct 2006       03-31-2007, 9:32 PM Reply
I had the same problem a little while ago and I had blown a fuse in my amp. Don't know if that is what has happened for you but something to check.
Old     (etakk7)      Join Date: Apr 2006       03-31-2007, 10:14 PM Reply
I had the same problem in my 2000 and after troubleshooting everything I had to replace the head unit. I believe I had the Clarion 5645 or something like that, and I read afterward that many people had to replace it.
