![Reply](images/buttons/reply.gif) |
03-29-2007, 6:38 AM
I'm helping a friend with a new ballast set up for his 03 x-star. His old reversible pumps (I assume they are the stock Jabsco) are on their last leg. Should I have him: - replace the 3 Jabsco pumps with 3 new Jabsco pumps - replace the 3 Jabsco pumps with 3 new Simer pumps - replace the 3 Jabsco pumps with 6 new Tsunami aerator pumps If he goes with the Tsunami pumps, will that present some difficulty in wiring them up since he will then have separate fill and empty pumps? How would you wire this? Thanks!
03-29-2007, 2:30 PM
anyone?
03-29-2007, 2:40 PM
I like impeller pumps, but they sometimes have priming issues and need to be installed below water line for the fill and below the ballast for empty.
03-29-2007, 3:16 PM
Flux do you mean aerator pumps? Pumps usually associated with impeller pumps are self priming and can be mounted above the water line. Aerators on the other hand needs to be below the water line. Wiring is easy David if he goes either route. Buy a three-way rocker switch and follow the directions. If it is not clear, I would do a search and see if someone has a diagram for him to see. BTW, I have a Jabsco pump and changed out the impeller with a plastic one. The original impeller someone sticks when it's dry causing the pump to refuse to turn. I thought it was on it's last leg, but a thread on WW recommended upgrading the impeller to a plastic one. Good Luck.
03-29-2007, 3:39 PM
DOH!!! Yeah, i meant aerators. I am sorry, trying to help and I completely confuse things by being a dumbhead. Yes, the aerators must be located either below the waterline for the fill or completely below the ballast for empty. They are pretty reliable and you can run them dry without worry. I have them in my 02 SANTE, they were stock, they have low amp draw and are fairly quick. Small size too.
03-29-2007, 3:48 PM
The 3-way rocker switches are already installed as the ballast, wiring, switches, and 3 pumps are all stock and still in place. Maybe I'll just recommend (for starters) that he get some plastic impellers for the existing pumps since they're only $7-8 a piece...
03-29-2007, 3:49 PM
If he traded out to aerator pumps, how would the wiring go? Just splice into the pos and neg? Is there a pos and neg for fill and a pos and neg for empty?
03-29-2007, 7:44 PM
Aerators seem to be more trouble free over the long haul.
03-30-2007, 6:41 AM
How would the wiring change go from reversible pumps to aerators? Obviously there would be 2 pumps per switch with that set up instead of 1 pump per switch. Anyone?
03-30-2007, 6:50 AM
IMO, you would be crazy to change from the original pumps if they still work. First of all, change the impellers. The new ones are yellow and work great. If the old ballast pumps are in decent condition, you can get them rebuilt at an alternator shop. The electrical motors are pretty easy to rebuild. The brushes and bearings are easy to replace. I bought a new pump to replace one of the old ones that the bearing went out on, rebuilt the old one, and now I have an extra on the boat at all times. I think you are just asking for more trouble to rewire and replace 3 rev. pumps with 6 aerators.
03-30-2007, 7:44 AM
The impellers for those pumps need to be replaced frequently, especially if you have the black rubber type. I replace mine at least twice a year because they wear down and start sticking. It sounds like the new yellow type are the way to go.
03-30-2007, 7:53 AM
Does BE Atlas sell the yellow impellers for the original pumps? Anyone have a direct link to buy that impeller? Thanks for the help.
03-30-2007, 8:01 AM
david, i have four aerator pumps running from two switches. if there is already several 3 pole 3 position switches in the boat, its a matter of wiring two pumps to the switch. i'm not sure how those wire up. if there is three poles on the switch, you'll be fine switching to aerators. if two ( i'm not sure how they work to reverse) then just replace the switch with a 3 pole 3 position switch. middle is ground, outside poles are for the pumps' pos lead. nothing to it really... (Message edited by denverd1 on March 30, 2007)
03-30-2007, 8:06 AM
if you decide to go that way, let me know. its really simple
03-31-2007, 10:26 AM
Sorry David, I can't remember how I wired my pumps, but just do a search on WW if you can't find an answer here. I'm with Byrd...If this was a brand new install, I would go the aerator route. If it's just the impeller needing replacement, then replace it with the yellow or blue impeller. Here is where you can get it in Sacramento area. They probably would ship if need be. Good luck. Cope & McPhetres Marine - Rocklin (YELLOW IMPELLER) 4409 Granite Drive Rocklin, CA 95677 USA Phone: 916-630-8800 Phone: 916-630-8800
04-02-2007, 7:01 AM
Thanks Van and Byrd. I'll give them a call. My buddy is in San Mateo so I might have him just head over to Cope's and pick up the new impellers.
