Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through February 21, 2007
Old     (wakecis)      Join Date: Jun 2005       02-15-2007, 9:05 AM Reply
i've got the old ERA's. the green ones. i bought m/l but should have gotten mediums. i cranked down the power strap one notch on both sides, lowering it. i also cranked down the toe overlays one notch, ONLY ON THE INSIDE.
is it okay to adjust the inside adn not the outside. i'm worried it would be too tight to do both. will it be ackward pressure?
anybody who's got advice i'd appreciate it.
on a side note....would it be good for wakeboarding / snowboarding, to make the board under the bindings cant slightly towards the middle/inward. that way a wider stance (anything wider than shoulders) would still square up your knees over your feet.
Old     (garret_s)      Join Date: Apr 2006       02-15-2007, 9:45 AM Reply
I would think that would be ok. If not, you can always put it back to stock.
On another note, I really had no idea what this sentence meant:
"on a side note....would it be good for wakeboarding / snowboarding, to make the board under the bindings cant slightly towards the middle/inward."
Please clarify so we can help.
Old     (wakecis)      Join Date: Jun 2005       02-15-2007, 9:57 AM Reply
first off, can't put it back because you have to cut the neoprene, both layers, to adjust.
instead of making the board level under the bindings, have the top of the board slant inwards on both sides (slightly)....your knees would be more centered over the middle of your feet, instead of having a wide stance and knees with uneven pressure. it would only work for people with very wide stances, but may help them go bigger with less knee tweak....
the way it is now, with a wide stance there is more pressure on the inside of the knee joint then outside. (i should know, i broke mine)
if you don't get it, i can draw a picture....
Old     (stephan)      Join Date: Nov 2002       02-15-2007, 11:28 AM Reply
I know my boots cant with the rocker line of the board.
