Ok, so I got my boat running last week, after replacing the fuel pump. Now the temp gauge doesn't seem to be working. After it idles for a while, the needle starts to move, and then it drops down to the bottom. If I turn the motor off, and then start it back up, the needle will go to the middle (180??) for a sec, and then drop back to the bottom. My question is: Is this a problem with the water temp sensor, or water temp sender? How can I trouble shoot? If I hook a multimeter to the gauge in the back, if there is no current coming through the wire, can I assume it is the sender? Thanks, Robb
